  • 测距要求比较准确点,要注意什么。求大神解答
    • # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = (89, 14, 39, -55, -87, -13)
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
              print(length)
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
    • https://singtown.com/learn/49590/
      最好用April tag。
