我用上位机发送1显示a=B"1"但是下面的if不会触发?
import sensor, image, time, math from pyb import UART uart = UART(3,4800, timeout_char=1000) # i使用给定波特率初始化 uart.init(4800, bits=8, parity=None, stop=1, timeout_char=1000) # 使用给定参数初始化 GRAYSCALE_THRESHOLD = [(0, 64)] ROIS = [ # [ROI, weight] (0, 0, 0, 0, 0), # You'll need to tweak the weights for your app (0, 50, 320, 30, 0.3), # depending on how your robot is setup. (0, 0, 0, 0, 0) ] weight_sum = 0 for r in ROIS: weight_sum += r[4] sensor.reset() # Initialize the camera sensor. sensor.set_contrast(3) sensor.set_gainceiling(16) sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale. sensor.set_framesize(sensor.VGA) # use QQVGA for speed. sensor.set_windowing((320, 240)) sensor.skip_frames(time = 2000) # Let new settings take affect. sensor.set_auto_gain(False,value=100) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() # Tracks FPS. a=0 def draw_keypoints(img, kpts): if kpts: print(kpts) img.draw_keypoints(kpts) img = sensor.snapshot() time.sleep(1000) kpts1 = image.load_descriptor("/desc.orb") img = sensor.snapshot() def high(x): x=x>>8 return x def low(x): x=x&0xff return x while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. print(0) if uart.any(): a=uart.read(1) print(a) if a==1: print(2) if a==2: print(3)
https://singtown.com/learn/50240/
看一下视频,b'1'是字节串bytes,不是字符串string,也不是数字int。
