这段代码哪里错了?
想做一个图像识别,使其检测到汉字后在串行终端输出该汉字,但是程序报错
import time, sensor, image from image import SEARCH_EX, SEARCH_DS sensor.reset() sensor.set_contrast(1) sensor.set_gainceiling(16) sensor.set_framesize(sensor.QQVGA) sensor.set_pixformat(sensor.GRAYSCALE) templates = ["/jin.pgm"] #保存多个模板 clock = time.clock() while (True): clock.tick() img = sensor.snapshot() for t in templates: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color = (255,0,0)) print(t[1:4]) #打印模板名字 if t in ['jin.pgm'] print('晋') else: print("error")
if后面没有冒号
