  • 两个标志位为什么标志为2不能执行,
    • import sensor, image,time,pyb,utime
      import sensor, image, time,utime
      p0 = pyb.Pin('P0', pyb.Pin.OUT_PP)
      p0.value(1)
      uart = UART(3, 19200)
      output_str=0
      yanse=0
      flag=2
      while 1:
      if uart.any():
      flag=uart.readline().decode()
      flag=int(flag)
      print(flag)
      if flag==1:
      sensor.set_windowing((240, 240)) # look at center 240x240 pixels of the VGA resolution.
      sensor.skip_frames(30)
      img.lens_corr(0.1) # strength of 1.8 is good for the 2.8mm lens.
      output_str="%s" % (code.payload())
      uart.write(output_str)
      print(output_str)
      pyb.delay(500)
      if output_str:
      p0.value(0)
      pyb.delay(10)
      p0.value(1)
      output_str=0
      flag=0
      if flag==2:
      thresholds = [(54, 74, 44, 91, -16, 52),(76, 48, -22, 75, -76, -25),(68, 83, -47, -22, -7, 40)] # generic_blue_thresholds
      utime.sleep_ms(2000)
      blobs=img.find_blobs(thresholds, pixels_threshold=5000, area_threshold=400)
      yanse="%s" % (blob.code())
      uart.write(yanse)
      print( yanse)
      pyb.delay(500)
      if yanse:
      p0.value(0)
      pyb.delay(10)
      p0.value(1)
      yanse=0
    • 代码缩进不对,逻辑不对。
    • 怎么修改呢,给一个提示可以吗
    • 第16行后面全部运行不到,因为在死循环外面。
