  • 在做人脸识别的时候,能够让电脑屏幕显示彩色的图像吗?
    • 在做人脸识别的时候,能够让电脑屏幕显示彩色的图像吗???
    • 没意义啊,因为人脸识别的算法是黑白的
    • @kidswong999 意思就是不能让电脑屏幕显示彩色的吗???因为老师想看看彩色的样子,并且想保存彩色的照片
    • 那你直接在程序里把GRAYSCALE改成RGB565就完事了。
    • @kidswong999 那还能进行人脸识别吗????
    • 你试试不就知道了😅 ,我刚才运行了一下没问题。
    • @kidswong999 啊???我直接运行就卡死了???我们的不一样吗???能麻烦你把代码给我看一下吗???
    • # Face Detection Example
      # This example shows off the built-in face detection feature of the OpenMV Cam.
      # Face detection works by using the Haar Cascade feature detector on an image. A
      # Haar Cascade is a series of simple area contrasts checks. For the built-in
      # frontalface detector there are 25 stages of checks with each stage having
      # hundreds of checks a piece. Haar Cascades run fast because later stages are
      # only evaluated if previous stages pass. Additionally, your OpenMV Cam uses
      # a data structure called the integral image to quickly execute each area
      # contrast check in constant time (the reason for feature detection being
      # grayscale only is because of the space requirment for the integral image).
      import sensor, time, image
      # Reset sensor
      # Sensor settings
      # HQVGA and GRAYSCALE are the best for face tracking.
      # Load Haar Cascade
      print(face_cascade)
      # FPS clock
          # Capture snapshot
          # Find objects.
          objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25)
          # Draw objects
          for r in objects:
              img.draw_rectangle(r)
          # Print FPS.
          # Note: Actual FPS is higher, streaming the FB makes it slower.
    • @kidswong999 谢谢了
