  • 为什么这样串口发送不了数据啊
      # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      # The below thresholds track in general red/green things. You may wish to tune them...
                    (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      uart = UART(3, 9600)
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
          for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
              uart.write(blob.code ())
               time.sleep(1000)
               print(blob.code ())
    • 一眼就看到好几个错误。
      1,缩进错了
      2,code和()之间不应该有空格
      3,blob.code()应该转成字符串发送。
      https://singtown.com/learn/50235/
    • 那怎么转换成字符串@kidswong999
    • 看我上面链接视频
    • 哦,谢谢了那缩进是怎么回事呢@kidswong999
