向OPENMV供电时,代码储存在SD卡中为何灯无显示?
下面两份代码,为何前者一供电,蓝灯就亮,而后者不行,我分别把代码都放入SD卡中测试了,难道不是一供电,OPENMV就运行SD卡中的代码么?还是别的问题?
# UART Control # # This example shows how to use the serial port on your OpenMV Cam. Attach pin # P4 to the serial input of a serial LCD screen to see "Hello World!" printed # on the serial LCD display. import sensor, image, pyb from pyb import UART RED_LED_PIN = 1 BLUE_LED_PIN = 3 sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others) pyb.LED(RED_LED_PIN).off() #pyb.LED(BLUE_LED_PIN).on() print("You're on camera!") # Always pass UART 3 for the UART number for your OpenMV Cam. # The second argument is the UART baud rate. For a more advanced UART control # example see the BLE-Shield driver. uart = UART(3, 9600, timeout_char=1000) while(True): pyb.LED(3).on() if uart.any(): a = uart.readline().decode() print(a) if a == "OK\r\n": sensor.snapshot().save("example1.jpg") uart.write("F") pyb.LED(BLUE_LED_PIN).off() print("Done! Reset the camera to see the saved image.")
# UART Control # # This example shows how to use the serial port on your OpenMV Cam. Attach pin # P4 to the serial input of a serial LCD screen to see "Hello World!" printed # on the serial LCD display. import sensor, image, pyb,time from pyb import UART RED_LED_PIN = 1 BLUE_LED_PIN = 3 # Always pass UART 3 for the UART number for your OpenMV Cam. # The second argument is the UART baud rate. For a more advanced UART control # example see the BLE-Shield driver. uart = UART(3, 9600, timeout_char=1000) sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others) sensor.skip_frames(time = 500) # Let new settings take affect. pyb.LED(RED_LED_PIN).off() sensor.skip_frames(time = 500) # Give the user time to get ready. print("You're on camera!") count = 0 while(True): pyb.LED(3).on() if uart.any(): a = uart.readline().decode() if a == "OK": count = count + 1 sensor.snapshot().save("%d.jpg"%(count)) # or "example.bmp" (or others) print("Done! Reset the camera to see the saved image.") uart.write("Finish") print("Send Finish.") time.sleep(100) pyb.LED(BLUE_LED_PIN).off() a = "\n"; else: sensor.snapshot() time.sleep(100)
