  • 串口接收一字符再拍照,并输入一次拍一张?
    • 我想用arduino板子想OPENMV发送一字符让它拍照,且输入一次拍一张,如何实现?代码如下:
      # UART Control
      # This example shows how to use the serial port on your OpenMV Cam. Attach pin
      # P4 to the serial input of a serial LCD screen to see "Hello World!" printed
      # on the serial LCD display.
      import sensor, image, pyb,time
      BLUE_LED_PIN = 3
      # Always pass UART 3 for the UART number for your OpenMV Cam.
      # The second argument is the UART baud rate. For a more advanced UART control
      # example see the BLE-Shield driver.
      uart = UART(3, 9600, timeout_char=1000)
      sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others)
      sensor.skip_frames(time = 500) # Let new settings take affect.
      pyb.LED(BLUE_LED_PIN).on()
      sensor.skip_frames(time = 500) # Give the user time to get ready.
      pyb.LED(BLUE_LED_PIN).off()
      count = 0;
          if uart.any():
              a = uart.readline().decode()
              if a == "OK\r\n":
                  count = count + 1
                  sensor.snapshot().save("%d.jpg"%(count)) # or "example.bmp" (or others)
                  uart.write("Finish")
                  time.sleep(100)
                  a = "\n";
              sensor.snapshot()
              time.sleep(100)
      运行时,显示错误
    • 有大神帮忙解决一下么?万分感谢!
    • 你用Arduino发送的数据的可能不是字符串。
      建议先用OpenMV 串口调试扩展板和星瞳串口助手测试。
