  • MemoryError: Out of fast Frame Buffer Stack Memory!
    • MemoryError: Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue!
      在试用模板示例的时候遇到MemoryError: Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue!问题是为什么啊
      我也加了sd卡了,是M2ram不够大吗
          if r:
              img.draw_rectangle(r)
      中 r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
      出问题
    • https://forum.singtown.com/topic/558/memory-error-fb-alloc-collision-内存不够与像素低
      另外,代码一定要让别人可以运行的,你的代码不全,运行不了。
