  • 在官方提供的openMV测距教程中,为什么视频中的效果不一样
    • 请在这里粘贴代码
      ```# Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = (76,96,-110,-30,8,60  )
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
              # print(length)
              print(Lm)
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
    • 请详细描述效果。
      那你是什么效果,视频是什么效果。
    • 已解决,因为灯光惹的祸
