追小球的小车程序问题
视频教程讲解追小球的小车程序 这里检测到面积为2000,小车后退 请问各位大佬那里程序体现到小车后退
@acpf 在 追小球的小车程序问题 中说:
import sensor, image, time import car from pid import PID from pyb import Servo # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. s1 = Servo(1) # P7 s2 = Servo(2) # P8 s3 = Servo(3) # P9 sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... green_threshold = (67, 100, -20, 93, 22, 75) size_threshold = 2000 x_pid = PID(p=0.5, i=1, imax=100) h_pid = PID(p=0.05, i=0.1, imax=50) def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([green_threshold]) if blobs: max_blob = find_max(blobs) x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) ''' for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy ''' img.draw_rectangle(max_blob[0:4]) # rect img.draw_cross(max_blob[5], max_blob[6]) # cx, cy x_output=x_pid.get_pid(x_error,1) h_output=h_pid.get_pid(h_error,1) print("h_output",h_output) car.run(-h_output-x_output,-h_output+x_output) else:
就是面积大于2000就后退,小于2000就前进。
都是这一句完成的。
我想在摄像头检测到面积为200时让机械手有动作 程序应该加在那里 谢谢
@kidswong999
if blobs: max_blob = find_max(blobs) if max_blob[2]*max_blob[3] <200: 你的动作 #下面都不用动 x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error)
@kidswong999
嗷嗷 谢谢
不是很懂程序,你的动作那里怎么写程序啊?如何使它停下来?
