  • 直线检测报错,求教!
    • 请问这是什么错误呀
      Line_threshold = (60, 100, -18, 32, -33, 56) # L A B
      min_degree = 0
      max_degree = 179
      #img_raw = sensor.snapshot().lens_corr(1.8).save('test.bmp')
      img_op=image.Image('123.bmp',copy_to_fb=True)
          #time.sleep(3000)
      img_op.binary([Line_threshold])
      #img_op.erode(2)
      img_op.dilate(1)
      img_op.erode(1)
      for l in img_op.find_line_segments(merge_distance=2, max_theta_differance=2) #(x_stride=3,y_stride=3,threshold = 1000, theta_margin = 10, rho_margin = 20):
              #if (min_degree <= l.theta()) and (l.theta() <= max_degree):
              img_op.draw_line(l.line(), color = (255, 0, 0))
              print(l.theta())
      sensor.flush()
      time.sleep(100)
    • 31行没有冒号,而且不应该有空行
    • @kidswong999
      嗯嗯 刚才忘了加冒号。。。改过之后变成这样了,说帧缓存区空间不够?这是怎么回事啊
      min_degree = 0
      max_degree = 179
      #time.sleep(3000)
      #img_op.erode(2)
      img_op.dilate(1)
      img_op.erode(1)
      for l in img_op.find_line_segments(merge_distance=10, max_theta_differance=2):
          print(l.theta())
      sensor.flush()
      time.sleep(100)
    • 新的问题,新的报错提示,请单独发帖子
    • 这行代码前面有未识别的字符,在IDE里面把前面的空格全部删掉,在上一行代码结尾回车换行,对齐后重新编译。
