python中应该如何判断接收到的字符串是发送的字符串?
UART Control
This example shows how to use the serial port on your OpenMV Cam. Attach pin
P4 to the serial input of a serial LCD screen to see "Hello World!" printed
on the serial LCD display.
from pyb import UARTAlways pass UART 3 for the UART number for your OpenMV Cam.
The second argument is the UART baud rate. For a more advanced UART control
example see the BLE-Shield driver.
uart = UART(3, 19200, timeout_char=1000)
if uart.any():
a = uart.readline()
if a == "OK\r\n"
sensor.snapshot().save("example1.jpg")
我是要用32串口发送个字符串“OK\r\n”,在python中判断接收到的字符串,然后拍照储存到SD卡。
你的if那一行,没有冒号吧
缩进也不对吧……
@5ewo 在 python中应该如何判断接收到的字符串是发送的字符串? 中说:
额,我缩进了4个空格,可能粘贴上去就没了,冒号是没加。但是还是不行,我记得例程中说还要复位一下,是不是必须这样。
代码格式问题
来自星瞳实验室APP: 必看[视频]:玩转星瞳论坛 https://forum.singtown.com/topic/57请贴完整的代码,以及报错提示。
# UART Control # # This example shows how to use the serial port on your OpenMV Cam. Attach pin # P4 to the serial input of a serial LCD screen to see "Hello World!" printed # on the serial LCD display. import time from pyb import UART # Always pass UART 3 for the UART number for your OpenMV Cam. # The second argument is the UART baud rate. For a more advanced UART control # example see the BLE-Shield driver. uart = UART(3, 19200, timeout_char=1000) while(True): if uart.any(): a = uart.readline().decode() print(a) if a == "OK\r\n": sensor.snapshot().save("example1.jpg")
File "", line 17, in
UnicodeError:
MicroPython v1.9.4-4510-g23e8457de on 2018-06-29; OPENMV3 with STM32F765
Type "help()" for more information.
你最后一句的缩进是错的。
# UART Control # # This example shows how to use the serial port on your OpenMV Cam. Attach pin # P4 to the serial input of a serial LCD screen to see "Hello World!" printed # on the serial LCD display. import sensor,image from pyb import UART # Always pass UART 3 for the UART number for your OpenMV Cam. # The second argument is the UART baud rate. For a more advanced UART control # example see the BLE-Shield driver. uart = UART(3, 9600, timeout_char=1000) while(True): if uart.any(): a = uart.readline().decode() print(a) if a == "OK\r\n": print("You're on camera!") img = sensor.snapshot() img.morph(1, [+2, +1, +0,\ +1, +1, -1,\ +0, -1, -2]) img.save("example.jpg") print("Done! Reset the camera to see the saved image.")
我不知道怎么缩进,我是对照例程改的。
File "", line 21, in
RuntimeError: Sensor Timeout!!
Type "help()" for more information.现在又不行了。
新的问题,单独新发帖子。
行,我先看看,不懂再发,感谢你!
