  • 新手 颜色识别
    • # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      import sensor, pyb,image, time
      from pyb import LED
      red_led   = LED(1)
      green_led = LED(2)
      blue_led  = LED(3)
      ir_led    = LED(4)
                    (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=100, area_threshold=200, merge=True):
      识别到红色后 绿灯亮,没有识别到红色红灯亮,新手python不会啊
    • if blobs:
          绿灯.亮()
          绿灯.灭()
    • 我只要是不知道这个if 语句往哪里加啊?麻烦您指教
    • 建议你先看看python的语法,比如对象什么的。
