巡线小车程序,在没有检测到线的时候,模块直接停止运行了,怎么避免??
pid.py程序
from pyb import millis
from math import pi, isnanclass PID:
_RC = 1/(2 * pi * 20)
def init(self, p=0, i=0, d=0, imax=0):
self._kp = float(p)
self._ki = float(i)
self._kd = float(d)
self._imax = abs(imax)
self._last_derivative = float('nan')def get_pid(self, error, scaler): tnow = millis() dt = tnow - self._last_t output = 0 if self._last_t == 0 or dt > 1000: dt = 0 self.reset_I() self._last_t = tnow delta_time = float(dt) / float(1000) output += error * self._kp if abs(self._kd) > 0 and dt > 0: if isnan(self._last_derivative): derivative = 0 self._last_derivative = 0 else: derivative = (error - self._last_error) / delta_time derivative = self._last_derivative + \ ((delta_time / (self._RC + delta_time)) * \ (derivative - self._last_derivative)) self._last_error = error self._last_derivative = derivative output += self._kd * derivative output *= scaler if abs(self._ki) > 0 and dt > 0: self._integrator += (error * self._ki) * scaler * delta_time if self._integrator < -self._imax: self._integrator = -self._imax elif self._integrator > self._imax: self._integrator = self._imax output += self._integrator return output def reset_I(self): self._integrator = 0 self._last_derivative = float('nan')
main.py程序
THRESHOLD = (60, 80, -10, 10, -10, 20) # Grayscale threshold for dark things...
from pyb import LED
rho_pid = PID(p=0.4, i=0)
theta_pid = PID(p=0.001, i=0)sensor.reset()
sensor.set_vflip(True)
sensor.set_hmirror(True)
clock = time.clock() # to process a frame sometimes.while(True):
if (line):
if line.theta()>90:
theta_err = line.theta()-180
逻辑有问题,最后那里,应该加缩进
好的,谢谢大神帮忙!!!!
