  • Value error sensor control failed 是怎么回事?
    • import pyb
      import sensor, image, time,utime
      import car
      from code_123 import code_123
      from code_132 import code_132
      from code_213 import code_213
      from code_231 import code_231
      from code_321 import code_321
      from code_312 import code_312
      from Read import uart_read
      from red import find_red
      from blue import find_blue
      from green import find_green
      from Test import wave_distance_process
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.skip_frames(10)
      m = [0,0,0]
          car.run(50,50)
          img.lens_corr(1)
              uart.write(code.payload()+'\0')
              m=list(code.payload())
              if(m!=[0,0,0]):
                  print(m)
                  if m[0]=='1' and m[1]=='2' and m[2]=='3':
                      find_red()
                      wave_distance_process()
                      while(wave_distance_process()>=6.0 and wave_distance_process()<=9.0):
                          find_red()
                      find_green()
                          find_green()
                      find_blue()
                          find_blue()
    • 你的程序我没有办法运行,不是全部的源码
