  • 自动登陆校园网:socketError: [ERRNO 107] ?
    • 按照示例WIFI中的 TCPclient 示例修改了以下,用来自动登陆校园网。以下是源码:
      源码:
      import socket
      host="ngw.bupt.edu.cn"
      port=80
      postData="POST /login HTTP/1.1\r\n"
      "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,/;q=0.8\r\n"
      "Accept-Encoding: gzip, deflate\r\n"
      "Accept-Language: zh-CN,zh;q=0.9\r\n"
      "Cache-Control: max-age=0\r\n"
      "Connection: keep-alive\r\n"
      "Content-Length: 41\r\n"
      "Content-Type: application/x-www-form-urlencoded\r\n"
      "Cookie: Hm_lvt_41e71a1bb3180ffdb5c83f253d23d0c0=1531817431; __lnkrntdmcvrd=-1; SessionId=4df2839f394641e7\r\n"
      "Host: ngw.bupt.edu.cn\r\n"
      "Origin: http://ngw.bupt.edu.cn\r\n"
      "Referer: http://ngw.bupt.edu.cn/index\r\n"
      "Upgrade-Insecure-Requests: 1\r\n"
      "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36\r\n\r\n"
      "user=2016211970&pass=033654&line=CUC-BRAS"
      def loginToSchoolNet():
      client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
      addr = socket.getaddrinfo(host,port)[0][-1]
      print("目标地址",addr)
      client.settimeout(100)
      client.connect((host,port))
      print("已连接到 ngw.bupt.edu.cn")
          client.send(postData)
          print("get response:",client.recv(1024))
          client.close()
          return 1
      except OSError as e:
          print("login socket error:",e)
          help(e)
          client.close()
          return -1
      运行时抛出异常:
      socket error: [Errno 107] ENOTCONN
      object [Errno 107] ENOTCONN is of type OSError
      emmmwhy....怎么肥西,运行示例的TCPclient没有问题的。。
    • 不知道,校园网是其他的认证,我不知道怎么做。
      你应该用路由器。
