  • WIFI通信历程 帧缓冲区无图像 socket error -116
      import sensor, image, time, network, usocket, sys, json
      green_threshold   = (   0,   80,  -70,   -10,   -0,   30)
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      # Init wlan module in AP mode.
      # You can block waiting for client to connect
      def response(s):
          client, addr = s.accept()
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Content-Type: application/json\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
              for b in blobs:
          client.send(json.dumps(blobs))
          client.close()
          # Create server socket
              # Bind and listen
              s.bind([HOST, PORT])
              s.listen(5)
              # Set server socket timeout
              s.settimeout(3)
              response(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
    • https://singtown.com/learn/50005/
      按照视频操作,使用chrome浏览器。
    • 此回复已被删除!
