  • 关于人脸检测矩形框不准或不显示的问题
    • import sensor,image,time
      sensor.set_framesize(sensor.HQVGA) # or sensor.QQVGA (or others)
      # Load up a face detection HaarCascade. This is object that your OpenMV Cam
      # can use to detect faces using the find_features() method below. Your OpenMV
      # Cam has fontalface HaarCascade built-in. By default, all the stages of the
      # HaarCascade are loaded. However, You can adjust the number of stages to speed
      # up processing at the expense of accuracy. The frontalface HaarCascade has 25
      # stages.
      print(face_cascade)
              # Threshold can be between 0.0 and 1.0. A higher threshold results in a
              # higher detection rate with more false positives. The scale value
              # controls the matching scale allowing you to detect smaller faces.
          faces = img.find_features(face_cascade, threshold=0.75, scale_factor=1.35)
          for r in faces:
              img.draw_rectangle(r)
      尝试过更改stage,threshold和scale_factor,但无法像视频教程14那样持续且准确地框出人脸,stage偏大时无法显示矩形框,想请问是openmv自带模型的问题?摄像头的问题?计算机配置问题?还是其他问题?
      print(face_cascade)在串行终端显示为"width":24, "height":24, "n_stages":25, "n_features":2913, "n_rectangles":6383
    • 可能是光线不好,灯应该正对人脸,如果背对这光,脸就会黑。
      你可以发个照片看一下。
