  • openmv接收到的数据为什么会这样子?给它发送3却输出b'3\r\n'
    • import sensor, image, time, math,pyb
      from pyb import Pin, Timer,UART
      uart = pyb.UART(3,9600,timeout_char=1000)#串口初始化
      # Tracks a black line. Use [(128, 255)] for a tracking a white line.
      GRAYSCALE_THRESHOLD = [(0, 150)]
      ROIS = [
              (0,0,64,64,0)
      #----------------------------------------寻找直线变量----------------------------------------#
      #---------------------------------------摄像头初始化-----------------------------------------#
      sensor.set_framesize(sensor.QQVGA)                  # 颜色追踪:160*120  光流检测:40*30
      sensor.skip_frames(20)
      sensor.set_auto_gain(False)                         # 颜色追踪关闭自动增益
      sensor.set_auto_whitebal(False)                     # 颜色追踪关闭白平衡
      Sum_x=0;
      Sum_y=0;
      flag=0;
      i=0;  #记录第几行数据
      j=0;  #记录直线数量
      led=pyb.LED(3)#必要的时候进行红外补光
      #检测圆形中心点的坐标
      center_x=0;
      center_y=0;
      center_update=1;#中心圆位置更新的标志
      center_x_old=0;
      center_y_old=0;
      center_pos_old=0;
      center_x_down=0;
      center_y_down=0;
      center_x_up=0;
      center_y_up=0;
      center_x_mid=0;
      center_y_mid=0;
      center_y_left=0;
      center_x_left=0;
      center_y_right=0;
      center_x_right=0;
      center_y_rect=0;
      center_x_rect=0;
      center_y_rect_old=0;
      center_x_rect_old=0;
      center_flag1=0;#上下
      center_flag2=0;#左右
      center_flag3=0;#通过roll来调整黑线的位置  通过yaw来调整机头方向  矩形1和2=0;
      center_flag4=0;
      center_flag5=0;
      center_flag6=0;
      turn_flag=0;#转弯的标志
      last_x=0;
      last_y=0;
      center_pos=0;
      yaw_angle=0;
      out_str1='';
      positive_ctrl = 0;
      f_x = (2.8 / 3.984)*160
      f_y = (2.8 / 2.952)*120
      c_x = 160*0.5
      c_y = 120*0.5
      def degrees(radians):
          return (180*randians)/math.pi
      led=pyb.LED(2)#必要的时候进行红外补光
      #定义一个定时发送数据的函数
      def tick(timer):#we will receive the timer object when being called
              global flag
              flag=1
      tim = Timer(4,freq=20)            # create a timer object using timer 4 - trigger at 1Hz
      tim.callback(tick)                # set the callback to our tick function
      #--------------------------------------while循环开始-----------------------------------------#
       if uart.any():
          positive_ctrl = uart.readline()
          uart.write("positive_ctrl=%s\n" %positive_ctrl)
          print(positive_ctrl)
       if(positive_ctrl == 1):
          if (flag==1):
              img=sensor.snapshot()
              img_old=img.copy()
              #--------------------------------------光流定点-----------------------------------------#
              img.lens_corr(1.8)#for 2.8mm lens...摄像头畸变纠正
              #--------------------------------------检测直线交点的位置---------------------------------------#
              #img.binary(GRAYSCALE_THRESHOLD,invert=1);
              #--------------------------------------寻找圆心的位置--------------------------------------#
              #检测圆形位置
              for r in ROIS:
                  blobs=img_old.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True,pixels_area=10) # r[0:4] is roi tuple.
                  if blobs:#如果找到了颜色块
                      largest_blob=max(blobs, key=lambda b: b.pixels())
                      if(largest_blob[4]>=10 and largest_blob[4]<=1500):#像素点个数
                          if(largest_blob[3]>=3 and largest_blob[3]<=60):
                              if(largest_blob[2]>=3 and largest_blob[2]<=60):
                                  center_y_rect=largest_blob.cy();
                                  center_x_rect=largest_blob.cx();
                                  img.draw_rectangle(largest_blob.rect())
              img.draw_cross(center_x_rect,center_y_rect,2)
              #50ms发送一次数据到飞控
              if(yaw_angle<0):
                  out_str1='-'
                  out_str1+= '%.2d'% int(-yaw_angle)    #寻找黑线中心位置计算出偏转角度
                  out_str1='+'
                  out_str1+= '%.2d'% int(yaw_angle)     #寻找黑线中心位置计算出偏转角度
              if(Sum_x<0):
                  out_str1+='-'
                  out_str1+='%.2d'%  int(-Sum_x);       #光流数据
                  out_str1+='+'
                  out_str1+='%.2d'%  int(Sum_x)         #寻找黑线中心位置计算出偏转角度
              if(Sum_y<0):
                  out_str1+='-'
                  out_str1+= '%.2d'% int(-Sum_y);       #光流数据
                  out_str1+='+'
                  out_str1+= '%.2d'% int(Sum_y);        #光流数据
              out_str1+='%.2d'%      int(center_pos);
              out_str1+='%.2d'%      int(center_x_rect); #圆心的位置
              out_str1+='%.2d'%      int(center_y_rect);
              out_str1+='%.2d'%      int(turn_flag);     #直角标志位
              out_str1+='%.2d'%      int(last_x);        #直角交点位置
              out_str1+='%.2d'%      int(last_y);
              uart.write('s'+out_str1+'#')
              #像素位移之和清零
              turn_flag=0;
              Sum_x=0
              Sum_y=0
              out_str1=''#清除之前的数据
              flag=0;
              #-----------------------------------串口打印数据-----------------------------------------#
       if(positive_ctrl==3):
              led.on()
              img.lens_corr(1.5)#for 2.8mm lens...摄像头畸变纠正
              for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y):
                  img.draw_rectangle(tag.rect(), color = (255,0,0))
                  img.draw_cross(tag.cx(), tag.cy(), color = (0,255,0))
                  #画框,画中心十字
                  print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(),\
                  degrees(tag.x_rotation()), degees(tag.y_rotation()), degrees(tag.z_rotation()))
                  #位置的单位是未知的,旋转单位是角度
                  print("Tx: %f, Ty: %f, Tz: %f, Rx: %f, Ry: %f, Rz: %f" % print_args)
                  Tx = tag.x_translation() #距标签的X轴长度
                  Ty = tag.y_translation()
                  output_str = "[%d,%d]"%(Tx,Ty) #标签的中心坐标
                  urat.write(output_str+'\r\n')
    • 你的串口助手默认行尾加了'\r\n',你换成星瞳串口助手
      https://singtown.com/singtownserialport/
      b是指字节串。比如b'3',就是说这个是字节串,b不是数据。
    • @kidswong999 那我想获取一个整数而不是字节串,应该怎么做呢?
    • 你发送的是字符串。。。不是数字。。。
