  • 运行后一扫到二维码就出现错误 oseeor: Not enough positional arguments!
    • # QRCode Example
      # This example shows the power of the OpenMV Cam to detect QR Codes
      # using lens correction (see the qrcodes_with_lens_corr.py script for higher performance).
      import sensor, image, time,lcd
              print(code)
              img.draw_string(code.payload())
          lcd.display(img)
    • img.draw_string(code.payload())函数调用的不对啊。要给一个字的坐标。
      参考,http://book.openmv.cc/example/03-Drawing/text-drawing.html
