在ide中打开下面的代码为什么不能高亮显示,全是黑白的
# Multi Color Blob Tracking Example # # This example shows off multi color blob tracking using the OpenMV Cam. import sensor, image, time # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green things. You may wish to tune them... thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (74, 15, 70, -78, -96, -19)] # generic_blue_thresholds # You may pass up to 16 thresholds above. However, it's not really possible to segment any # scene with 16 thresholds before color thresholds start to overlap heavily. sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here. while(True): clock.tick() img = sensor.snapshot() for blob in img.find_blobs([thresholds[0]], pixels_threshold=200, area_threshold=200): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) print('1 red:' + str(blob.x())) for blob in img.find_blobs([thresholds[1]], pixels_threshold=200, area_threshold=200): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) print('2 green:' + str(blob.x())) for blob in img.find_blobs([thresholds[2]], pixels_threshold=200, area_threshold=200): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) print('3 blue:' + str(blob.x())) # print(clock.fps())
因为你没有把文件保存成.py后缀名
哦是的!谢谢大佬
