  • 关于代码问题
    • from pyb import millis
      from math import pi, isnan
      class PID:
          _RC = 1/(2 * pi * 20)
              self._kp = float(p)
              self._ki = float(i)
              self._kd = float(d)
              self._imax = abs(imax)
              tnow = millis()  #以毫秒技计数
              dt = tnow - self._last_t
              output = 0
                  dt = 0
                  self.reset_I()
              self._last_t = tnow
              delta_time = float(dt) / float(1000)#秒
              output += error * self._kp
                  if isnan(self._last_derivative):#若x非数字返回ture
                      derivative = 0
                      self._last_derivative = 0
                  self._last_error = error
              output *= scaler
                  output += self._integrator
              return output
          def reset_I(self):
              self._integrator = 0
      其中self._last_derivative = float('nan') nan是神魔意思   这个字符能转化成数字
