  • openmv不能识别小球然后驱动小车,就是追踪小球那出现了问题,求大神解决
    • # Blob Detection Example
      import car
      red_threshold   = (39, 71, 47, 71, -22, 60)
      size_threshold = 2000
              print("x error: ", x_error)
              for b in blobs:
              print("h_output",h_output)
              car.run(10,-10)
