完整情况为 插入USB线 闪绿灯 闪蓝灯 连接 不亮 开始跑例子 闪绿灯 断开 闪蓝灯 求求大佬们 现在真的很急
# This work is licensed under the MIT license. # Copyright (c) 2013-2023 OpenMV LLC. All rights reserved. # https://github.com/openmv/openmv/blob/master/LICENSE # # Find Rects Example # # This example shows off how to find rectangles in the image using the quad threshold # detection code from our April Tags code. The quad threshold detection algorithm # detects rectangles in an extremely robust way and is much better than Hough # Transform based methods. For example, it can still detect rectangles even when lens # distortion causes those rectangles to look bent. Rounded rectangles are no problem! # (But, given this the code will also detect small radius circles too)... import sensor import time sensor.reset() sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time=2000) clock = time.clock() while True: clock.tick() img = sensor.snapshot() # `threshold` below should be set to a high enough value to filter out noise # rectangles detected in the image which have low edge magnitudes. Rectangles # have larger edge magnitudes the larger and more contrasty they are... for r in img.find_rects(threshold=10000): img.draw_rectangle(r.rect(), color=(255, 0, 0)) for p in r.corners(): img.draw_circle(p[0], p[1], 5, color=(0, 255, 0)) print(r) print("FPS %f" % clock.fps())
OpenMV更新到最新固件,更新固件后重试。
如果不行的话可以尝试使用DFU方法烧录固件:https://singtown.com/cn/learn/50903
下单了一个新的,谢谢官方您的回应我的·问题 ,我看升级固件的视频是很早之前的了,打开现在的固件升级DFU非常迷茫,不会使用,我的H7 PLUS 可以跑其他例子,但对于识别矩形的例子无法跑,怀疑是其他问题,固件通过常规升级到最新版本了已经,但仍然无法使用,可以再教教我。QQ:783885191
