  • RT1062接Lepton出现花点,温度值偏差大
    • # This work is licensed under the MIT license.
      # Lepton Get Object High Temp Example
      # This example shows off how to get an object's temperature using color tracking.
      # By turning the AGC off and setting a max and min temperature range you can make the lepton into
      # a great sensor for seeing objects of a particular temperature. That said, the FLIR lepton is a
      # microblobometer and not a thermophile. So, it needs to re-calibrate itself often (which is called
      # flat-field-correction - FFC). Additionally, microblobmeter devices require pprocessing support
      # onboard to deal with the effects of temperature drift which is called radiometry support.
      # FLIR Lepton Shutter Note: FLIR Leptons with radiometry and a shutter will pause the video often
      # as they heatup to re-calibrate. This will happen less and less often as the sensor temperature
      # stabilizes. You can force the re-calibration to not happen if you need to via the lepton API.
      # However, it is not recommended because the image will degrade overtime.
      # If you are using a LEPTON other than the Lepton 3.5 this script may not work perfectly as other
      # leptons don't have radiometry support or they don't activate their calibration process often
      # enough to deal with temperature changes (FLIR 2.5).
      import sensor
      # Color Tracking Thresholds (Grayscale Min, Grayscale Max)
      threshold_list = [(100, 255)]  # track very hot objects
      # Set the target temp range here
      # 500C is the maximum the Lepton 3.5 sensor can measure
      # At room temperature it's max is ~380C
      min_temp_in_celsius = 0.0
      max_temp_in_celsius = 100.0
      print("Resetting Lepton...")
      # These settings are applied on reset
      # Enable measurement mode with high temp
      sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True, True)
      sensor.ioctl(
          sensor.IOCTL_LEPTON_SET_MEASUREMENT_RANGE, min_temp_in_celsius, max_temp_in_celsius
      print(
          "Lepton Res (%dx%d)"
              sensor.ioctl(sensor.IOCTL_LEPTON_GET_WIDTH),
              sensor.ioctl(sensor.IOCTL_LEPTON_GET_HEIGHT),
      print(
          "Radiometry Available: "
          + ("Yes" if sensor.ioctl(sensor.IOCTL_LEPTON_GET_RADIOMETRY) else "No")
      sensor.skip_frames(time=5000)
      def map_g_to_temp(g):
          return (
              (g * (max_temp_in_celsius - min_temp_in_celsius)) / 255.0
          ) + min_temp_in_celsius
          for blob in img.find_blobs(
              threshold_list, pixels_threshold=200, area_threshold=200, merge=True
              stats = img.get_statistics(thresholds=threshold_list, roi=blob.rect())
              img.draw_string(
                  blob.x(),
                  blob.y() - 10,
                  "%.2f C" % map_g_to_temp(stats.mean()),
                  mono_space=False,
          print(
              "FPS %f - Lepton Temp: %f C"
              % (clock.fps(), sensor.ioctl(sensor.IOCTL_LEPTON_GET_FPA_TEMPERATURE))
      ![0_1743649796238_1743649756904.jpg](https://fcdn.singtown.com/62dfd5fd-22df-479e-915e-bef329a5b61d.jpg)
      是用的IDE版本是4.4.7。固件版本是4.5.9。板子型号是openMV Cam RT1062 Legacy。请问怎么可以使用这个连续测温模式?
    • @3azq 在代码中取消sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True, True),也就是取消测温模式和连续测温后,画面恢复正常,但是温度值明显不对0_1743650208268_1743650172940.jpg
      开启sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True, True)后,直接花屏
      1. 必须升级固件,现在是4.6.20
      2. 运行这个代码:
      # 本作品采用MIT许可证授权。
      # 版权所有 (c) 2013-2023 OpenMV LLC。保留所有权利。
      # Lepton 获取物体温度示例
      # 如果您使用的LEPTON不是Lepton 3.5,此脚本可能无法完美运行,因为其他
      # 其他lepton没有辐射测量支持,或者它们的校准过程不够频繁
      # 以应对温度变化(FLIR 2.5)。
      import sensor
      import image
      # 颜色跟踪阈值(灰度最小值,灰度最大值)
      threshold_list = [(200, 255)]
      # 在此设置目标温度范围
      min_temp_in_celsius = 20.0
      max_temp_in_celsius = 40.0
      # 这些设置在重置时应用
      sensor.ioctl(sensor.IOCTL_LEPTON_SET_MODE, True)
      sensor.ioctl(
          sensor.IOCTL_LEPTON_SET_RANGE, min_temp_in_celsius, max_temp_in_celsius
      print(
      print(
      # 只有像素数超过“pixel_threshold”且面积超过“area_threshold”的blob才会被
      # “find_blobs”返回。如果更改了“pixels_threshold”和“area_threshold”,请进行相应调整。
      # 相机分辨率。"merge=True" 合并图像中所有重叠的斑点。
          return (
          blob_stats = []
          blobs = img.find_blobs(
          # 将统计信息收集到元组列表中
              blob_stats.append(
                      blob.x(),
                      blob.y(),
                      map_g_to_temp(
                          img.get_statistics(
                          ).mean()
          img.to_rainbow(color_palette=image.PALETTE_IRONBOW)  # 为其上色
          # 在彩色图像上绘制内容
          for blob_stat in blob_stats:
              img.draw_string(
                  blob_stat[0], blob_stat[1] - 10, "%.2f C" % blob_stat[2], mono_space=False
          print(
              % (clock.fps(), sensor.ioctl(sensor.IOCTL_LEPTON_GET_FPA_TEMP))
