  • 在edge lmpulse上训练的模型复制到板子上两秒就死机了
      # Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      import sensor, image, time, os, ml, math, uos, gc
      from ulab import numpy as np
      net = None
      labels = None
      min_confidence = 0.5
          net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          ob, oh, ow, oc = model.output_shape[0]
          x_scale = inputs[0].roi[2] / ow
          y_scale = inputs[0].roi[3] / oh
          scale = min(x_scale, y_scale)
          l = [[] for i in range(oc)]
          for i in range(oc):
              blobs = img.find_blobs(
                  threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = (
                  x = int((x * scale) + x_offset)
                  w = int(w * scale)
                  h = int(h * scale)
          return l
              if i == 0: continue  # background class
              if len(detection_list) == 0: continue  # no detections for this class?
              for x, y, w, h, score in detection_list:
                  print(f"x {center_x}\ty {center_y}\tscore {score}")
          print(clock.fps(), "fps", end="\n\n")![1_1742631114530_IMG_4107.jpeg](正在上传 0%) ![0_1742631114530_IMG_4106.jpeg](正在上传 0%)
    • 0_1742642372016_屏幕截图 2025-03-22 164324.png 0_1742642378669_屏幕截图 2025-03-22 164309.png
    • 兄弟解决了吗,我的问题跟你一样,急死了😂
    • edge impulse的模型只能在OpenMV4 H7 Plus上使用,不能在OpenMV4 H7上使用。
    • @daw4 固件太新了,回退一下
