  • NCC模板匹配无法运行
    • from image import SEARCH_DS
      Reset sensor
      Set sensor settings
      Max resolution for template matching with SEARCH_EX is QQVGA
      You can set windowing to reduce the search image.
      sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      Load template.
      Template should be a small (eg. 32x32 pixels) grayscale image.
      template = image.Image("/3")
      Run template matching
      r = img.find_template(
          template, 0.70, step=4, search=SEARCH_EX
      )  # , roi=(10, 0, 60, 60))
      if r:
          img.draw_rectangle(r)
      已经进行过保存完模板重新上电的操作了,但还是无法运行,请求指导
    • 必须是pgm文件,应该是是image.Image("./3.pgm")
    • 我也是但是
      0_1742801658759_f3102f41-29f8-4a94-ab73-245d267b883c-image.png 0_1742801685916_fe4bf878-083d-4667-bdd8-f83967223423-image.png
    • @gqlm 把"/1.pgm"改为"./1.pgm"
