  • import sensor, image, time, os, uos, gc,ml显示没有ml库
      from ulab import numpy as np
      net = None
      labels = None
          net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          print(e)
          predictions_list = list(zip(labels, net.predict([img])[0].flatten().tolist()))
          print(clock.fps(), "fps")
    • 更新固件,现在是4.6.20
