# Black Grayscale Line Following Example
# Making a line following robot requires a lot of effort. This example script
# shows how to do the machine vision part of the line following robot. You
# can use the output from this script to drive a differential drive robot to
# follow a line. This script just generates a single turn value that tells
# your robot to go left or right.
# For this script to work properly you should point the camera at a line at a
# 45 or so degree angle. Please make sure that only the line is within the
# camera's field of view.
import sensor
import math
# Tracks a black line. Use [(128, 255)] for a tracking a white line.
GRAYSCALE_THRESHOLD = [(0, 64)]
# Each roi is (x, y, w, h). The line detection algorithm will try to find the
# centroid of the largest blob in each roi. The x position of the centroids
# will then be averaged with different weights where the most weight is assigned
# to the roi near the bottom of the image and less to the next roi and so on.
ROIS = [ # [ROI, weight]
(0, 100, 160, 20, 0.7), # You'll need to tweak the weights for your app
(0, 50, 160, 20, 0.3), # depending on how your robot is setup.
(0, 0, 160, 20, 0.1),
# Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
weight_sum = 0
for r in ROIS:
weight_sum += r[4] # r[4] is the roi weight.
# Camera setup...
sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
sensor.skip_frames(time=2000) # Let new settings take affect.
cl
