为什么按照视频教程驱动LCD显示屏之后依旧是白屏,无法正常显示,openmv的IDE也是最新版本的?
# This work is licensed under the MIT license. # Copyright (c) 2013-2023 OpenMV LLC. All rights reserved. # https://github.com/openmv/openmv/blob/master/LICENSE # # Single Color RGB565 Blob Tracking Example # # This example shows off single color RGB565 tracking using the OpenMV Cam. import sensor import time import math,lcd threshold_index = 0 # 0 for red, 1 for green, 2 for blue # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green/blue things. You may wish to tune them... thresholds = [ (30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (0, 30, 0, 64, -128, 0), ] # generic_blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time=2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() lcd.init()# Initialize the lcd screen. # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" merges all overlapping blobs in the image. while True: clock.tick() img = sensor.snapshot() for blob in img.find_blobs( [thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True, ): # These values depend on the blob not being circular - otherwise they will be shaky. if blob.elongation() > 0.5: img.draw_edges(blob.min_corners(), color=(255, 0, 0)) img.draw_line(blob.major_axis_line(), color=(0, 255, 0)) img.draw_line(blob.minor_axis_line(), color=(0, 0, 255)) # These values are stable all the time. img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) lcd.display(img) # Take a picture and display the image. # Note - the blob rotation is unique to 0-180 only. img.draw_keypoints( [(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20 ) print(clock.fps())
https://book.openmv.cc/example/11-LCD-Shield/lcd.html
运行这个测试代码有没有问题?
