  • 请问怎么在openmvide里用yolov5训练的tflite-int8模型?
    • @sq35 # Edge Impulse - OpenMV FOMO Object Detection Example
      This work is licensed under the MIT license.
      Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      https://github.com/openmv/openmv/blob/master/LICENSE
      import sensor, image, time, os, ml, math, uos, gc
      from ulab import numpy as np
      net = None
      labels = None
      min_confidence = 0.5
      net = ml.Model("best.tflite", load_to_fb=uos.stat('best.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
      raise Exception('Failed to load "best.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')
      (255, 0, 0),
      ( 0, 255, 0),
      (255, 255, 0),
      ( 0, 0, 255),
      (255, 0, 255),
      ( 0, 255, 255),
      (255, 255, 255),
      ob, oh, ow, oc = model.output_shape[0]
      x_scale = inputs[0].roi[2] / ow
      y_scale = inputs[0].roi[3] / oh
      scale = min(x_scale, y_scale)
      l = [[] for i in range(oc)]
      for i in range(oc):
          blobs = img.find_blobs(
              threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
          for b in blobs:
              rect = b.rect()
              x, y, w, h = rect
              score = (
              x = int((x * scale) + x_offset)
              w = int(w * scale)
              h = int(h * scale)
      return l
          if i == 0: continue  # background class
          if len(detection_list) == 0: continue  # no detections for this class?
          for x, y, w, h, score in detection_list:
              print(f"x {center_x}\ty {center_y}\tscore {score}")
      这是openmvide里的代码,我修改了yolov5源代码里的一些参数来减小模型
    • 这个还在开发。等做好了会提供一个训练和部署的代码。
