  • 例子“find_apriltags.py”无法识别TAG16H5等类型的April tag码,这是为什么?
    • # This work is licensed under the MIT license.
      # AprilTags Example
      import sensor
      import math
      sensor.skip_frames(time=2000)
      # Note! Unlike find_qrcodes the find_apriltags method does not need lens correction on the image to work.
      # Please use the TAG36H11 tag family for this script - it's the recommended tag family to use.
          for tag in img.find_apriltags():
              img.draw_rectangle(tag.rect, color=(255, 0, 0))
              img.draw_cross(tag.cx, tag.cy, color=(0, 255, 0))
              print_args = (tag.name, tag.id, (180 * tag.rotation) / math.pi)
              print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
      我并没有对代码进行任何修改,也尝试识别了其他类型的代码,发现只能识别出TAG36H11的April tag。请问这是为什么?April tag码都是用Openmv IDE的编译器生成的。
    • https://github.com/openmv/openmv/pull/2401
      为了减少资源占用,所以只保留了TAG36H11。
