  • 颜色识别的判断及其反应
    • 当找到颜色块时,怎样控制引脚做出高低电位的反应?
    • 这是我用过的程序,你看看有没有捏能用到的地方
      # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      #将蓝灯赋值给变量led
      led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
      usb = pyb.USB_VCP() # This is a serial port object that allows you to
      # communciate with your computer. While it is not open the code below runs.
                   (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      #ROI=(80,30,15,15)#左上方
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True):
              print(123)
          if blob.cx()==img.width()/2:
              print(666)
              led.on()
              time.sleep(600)
              print(blob)  #rotation为旋转的弧度,通过这个来确认垂直时候停止
              print(blob.code())   #打印出来相应颜色的代码,可以通过这个进行串口通信
         #此处为lcd输出XY坐标img.draw_string(100,100,'x='+str(blob.cx()), color=(0,0,0))
        #img.draw_string(100,100,'y=+'str(blob.cy()), color=(0,0,0))
       # thresholds[0]为色域的第一个,即为红色,见视频颜色16min
      #通过90度,小ROI,代码确定为红色,中间均分,坐标中间,从而进行相应的定位
