颜色识别的判断及其反应
当找到颜色块时,怎样控制引脚做出高低电位的反应?
这是我用过的程序,你看看有没有捏能用到的地方
# Single Color RGB565 Blob Tracking Example # # This example shows off single color RGB565 tracking using the OpenMV Cam. import sensor, image, time,pyb #将蓝灯赋值给变量led led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4. usb = pyb.USB_VCP() # This is a serial port object that allows you to # communciate with your computer. While it is not open the code below runs. threshold_index = 0 # 0 for red, 1 for green, 2 for blue # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green/blue things. You may wish to tune them... thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() #ROI=(80,30,15,15)#左上方 # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" merges all overlapping blobs in the image. while(True): clock.tick() img = sensor.snapshot() for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) print(123) if blob.cx()==img.width()/2: print(666) led.on() time.sleep(600) print(blob) #rotation为旋转的弧度,通过这个来确认垂直时候停止 print(blob.code()) #打印出来相应颜色的代码,可以通过这个进行串口通信 #此处为lcd输出XY坐标img.draw_string(100,100,'x='+str(blob.cx()), color=(0,0,0)) #img.draw_string(100,100,'y=+'str(blob.cy()), color=(0,0,0)) # thresholds[0]为色域的第一个,即为红色,见视频颜色16min #打印出来相应颜色的代码,可以通过这个进行串口通信 #通过90度,小ROI,代码确定为红色,中间均分,坐标中间,从而进行相应的定位
