  • 人脸追踪过程中识别很慢,舵机云台动两下就不动了,硬件没问题的,下面是main.py和pid.py是用来实现云台人脸追踪的
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      sensor.set_contrast(3)
      sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.s
              tilt_error =max_blob[1]+max_blob[3]/2
              img.draw_cross(int(max_blob[0]+max_blob[2]/2), int(max_blob[1]+max_blob[3]/2)) # cx, cy
      from pyb import millis
      from math import pi, isnan
      class PID:
          _RC = 1/(2 * pi * 20)
              self._kp = float(p)
              self._ki = float(i)
              self._kd = float(d)
              self._imax = abs(imax)
              tnow = millis()
              dt = tnow - self._last_t
              output = 0
                  dt = 0
                  self.reset_I()
              self._last_t = tnow
              output += error * self._kp
                      derivative = 0
                      self._last_derivative = 0
                  self._last_error = error
              output *= scaler
                  output += self._integrator
              return output
          def reset_I(self):
              self._integrator = 0
