  • 人眼识别示例代码报错 OSError: Could not find the file 如何解决?
    • # This work is licensed under the MIT license.
      # Face Eye Detection Example
      # This script uses the built-in frontalface detector to find a face and then
      # the eyes within the face. If you want to determine the eye gaze please see the
      # iris_detection script for an example on how to do that.
      import sensor
      import image
      # Reset sensor
      # Sensor settings
      # Load Haar Cascade
      eyes_cascade = image.HaarCascade("eye", stages=24)
      print(face_cascade, eyes_cascade)
      # FPS clock
          # Capture snapshot
          # Find a face !
          objects = img.find_features(face_cascade, threshold=0.5, scale_factor=1.5)
          # Draw faces
          for face in objects:
              img.draw_rectangle(face)
              # Now find eyes within each face.
              # Note: Use a higher threshold here (more detections) and lower scale (to find small objects)
              eyes = img.find_features(
                  eyes_cascade, threshold=0.5, scale_factor=1.2, roi=face
              for e in eyes:
                  img.draw_rectangle(e)
          # Print FPS.
          # Note: Actual FPS is higher, streaming the FB makes it slower.
