# AprilTags Example
import sensor
import math
sensor.skip_frames(time=2000)
sensor.set_auto_whitebal(False) # must turn this off to prevent image washout...
# Note! Unlike find_qrcodes the find_apriltags method does not need lens correction on the image to work.
# Please use the TAG36H11 tag family for this script - it's the recommended tag family to use.
for tag in img.find_apriltags():
img.draw_rectangle(tag.rect, color=(255, 0, 0))
img.draw_cross(tag.cx, tag.cy, color=(0, 255, 0))
print_args = (tag.name, tag.id, (180 * tag.rotation) / math.pi)
print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
