怎么把这个代码改成用灰度图像巡线呢???自己试着改了教程的代码但画不出来线
THRESHOLD = (27, 40, -27, 127, -28, 7) # Grayscale threshold for dark things...
from pyb import LED
import car
rho_pid = PID(p=0.4, i=0)
theta_pid = PID(p=0.001, i=0)
LED(1).on()
LED(2).on()
LED(3).on()
sensor.set_vflip(True)
sensor.set_hmirror(True)
sensor.set_pixformat(sensor.GRAYSCALE)#RGB565
clock = time.clock() # to process a frame sometimes.
if (line):
if line.theta()>90:
theta_err = line.theta()-180
img.draw_line(line.line(), color = 10)
if line.magnitude()>8:
car.run(50+output, 50-output)
car.run(0,0)
car.run(50,-50)
pass
print(clock.fps())请在这里粘贴代码
