  • 怎么把这个代码改成用灰度图像巡线呢???自己试着改了教程的代码但画不出来线
    • THRESHOLD = (27, 40, -27, 127, -28, 7) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.set_pixformat(sensor.GRAYSCALE)#RGB565
      sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds
      clock = time.clock() # to process a frame sometimes.
      line = img.get_regression([(100,100)], robust = True)
      if (line):
      if line.theta()>90:
      theta_err = line.theta()-180
      img.draw_line(line.line(), color = 10)
      if line.magnitude()>8:
      car.run(50+output, 50-output)
      car.run(0,0)
      car.run(50,-50)
      pass
      请在这里粘贴代码
