  • 这个如何解决,之前用着是没有问题着
    • 代码文本发一下,OpenMV的硬件是什么?固件版本是什么?
    • @kidswong999
      uart = UART(3,115200)
      threshold_list = [(200, 255)]
      min_temp_in_celsius = 20.0
      max_temp_in_celsius = 40.0
      print("Resetting Lepton...")
      sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True)
      sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_RANGE, min_temp_in_celsius, max_temp_in_celsius)
      print("Lepton Res (%dx%d)" % (sensor.ioctl(sensor.IOCTL_LEPTON_GET_WIDTH),
                                    sensor.ioctl(sensor.IOCTL_LEPTON_GET_HEIGHT)))
      print("Radiometry Available: " + ("Yes" if sensor.ioctl(sensor.IOCTL_LEPTON_GET_RADIOMETRY) else "No"))
      def map_g_to_temp(g):
          return ((g * (max_temp_in_celsius - min_temp_in_celsius)) / 255.0) + min_temp_in_celsius
          if (uart.any()):
              if b'r' in uart.read():
                  blob_stats = []
                  blobs = img.find_blobs(threshold_list, pixels_threshold=200, area_threshold=200, merge=True)
                      blob_stats.append((blob.x(), blob.y(), map_g_to_temp(img.get_statistics(thresholds=threshold_list,
        roi=blob.rect()).mean())))
                  img.to_rainbow(color_palette=sensor.PALETTE_IRONBOW)
                  img.to_rainbow()
                  for blob_stat in blob_stats:
                      img.draw_string(blob_stat[0], blob_stat[1] - 10, "%.2f C" % blob_stat[2], mono_space=False)
                  uart.write("start")
                  uart.write(str(blob_stats))
                  uart.write("end")
                  uart.write(img.compressed(quality=50))
                  print("FPS %f - Lepton Temp: %f C" % (clock.fps(), sensor.ioctl(sensor.IOCTL_LEPTON_GET_FPA_TEMPERATURE)))
    • @kidswong999 openmv- H7-plus +flir热成像模组
    • @kidswong999 你好固件版本如何查看
