  • 这是寻找最大色块的程序,电脑连上摄像头以后大部分时候识别不到,偶尔能识别到
      from pyb import Pin, Timer
      #屏幕 320*240
      height = 120
      #sensor.set_windowing(320,240))
      red_block_x=1
      green_block_x=2
      blue_block_x=3
      message=000
      #lcd.init() # Initialize the lcd screen.
      Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      The below thresholds track in general red/green/blue things. You may wish to tune them...
      thresholds = [(23, 55, 26, 64, -19, 42), # generic_red_thresholds
      (53, 74, -42, -7, -29, 2), # generic_green_thresholds
      (53, 76, -30, 40, -68, -27)] # generic_blue_thresholds
      objthresholds = [(61, 86, 11, 44, -33, 0), # generic_red_thresholds
      (34, 97, -11, -46, -52, 40), # generic_green_thresholds
      (69, 51, 5, 44, -29, -50)] # generic_blue_thresholds
      graythreshold=[(100,255)]
      K=5000
      light = Timer(2, freq=1800).channel(1, Timer.PWM, pin=Pin("P6"))#ferq=50000
      light.pulse_width_percent(2)#30
      if(C_led):
      # 控制亮度 0~100##############################################
      CS_flag=1
      if(CS_flag):
          #light = Timer(2, freq=1800).channel(1, Timer.PWM, pin=Pin("P6"))#ferq=50000
          #light.pulse_width_percent(2)#30
          blobs = img.find_blobs([thresholds[0],thresholds[1],thresholds[2]],x_stride=40,y_stride=40,pixels_threshold=1000)
              data=[]
              img.draw_cross(max_blob.cx(),max_blob.cy())
              img.draw_circle(max_blob.cx(),max_blob.cy(),max_blob.cx()-max_blob.x(), color = (255, 255, 255))
              X =int(max_blob.cx()-img.width()/2)
              Y =int(max_blob.cy()-img.height()/2)
              data.append((X,Y))
              data_out = json.dumps(set(data))
              uart.write('CS'+data_out +"\r\n")
              print(data_out)
              print("偏移坐标 : ",X, Y)
              #print("Y轴偏移坐标 : ",Y)
              #print("帧率 : ",clock.fps())
              CS_flag = 0
