  • roi没有重叠是咋回事?
    • 0_1729324854164_屏幕截图 2024-10-18 222333.png 0_1729324504432_屏幕截图 2024-10-18 222333.png
      import sensor, image, time, display, math
      sensor.set_auto_gain(False)
      #sensor.set_windowing((160, 120))
      uart = UART(3, 9600)
      #阈值设置
      color = (0, 43, -128, 127, -128, 127)
      mode = 0
      rois = []
      #------------------------------定义缩小四边形函数
      def shrink_rect(corners, shrink_by):
          # 计算中心点
          cx = int(sum(p[0] for p in corners) / len(corners))
          cy = int(sum(p[1] for p in corners) / len(corners))
          # 缩小每个顶点
          new_corners = []
          for p in corners:
              dx = p[0] - cx
              dy = p[1] - cy
              distance = math.sqrt(dx * dx + dy * dy)
              scale = (distance - shrink_by) / distance if distance > 0 else 0
              new_x = int(cx + dx * scale)
              new_y = int(cy + dy * scale)
              new_corners.append((new_x, new_y))
          return new_corners, cx, cy
      #------------------------------求两点中点坐标
      def Make_dian(new_xy):
          mid2x = abs((new_xy[2][0] + new_xy[3][0]) / 2)
          mid4x = abs((new_xy[3][0] + new_xy[0][0]) / 2)
          mid6x = abs((new_xy[2][0] + new_xy[1][0]) / 2)
          mid8x = abs((new_xy[1][0] + new_xy[0][0]) / 2)
          mid2y = abs((new_xy[2][1] + new_xy[3][1]) / 2)
          mid4y = abs((new_xy[3][1] + new_xy[0][1]) / 2)
          mid6y = abs((new_xy[2][1] + new_xy[1][1]) / 2)
          mid8y = abs((new_xy[1][1] + new_xy[0][1]) / 2)
          newmid = [int(mid2x), int(mid2y),int(mid4x), int(mid4y), int(mid6x), int(mid6y), int(mid8x), int(mid8y)]
      #    print(newmid)
          return newmid
      #def find_rois(max_rect):
      #def color_blob(color, roi_r):
      #    for blobs in img.find_blobs([color], pixels_threshold=100, area_threshold=100):
      #        if blobs:
      #            cx = blobs.cx()
      #            cy = blobs.cy()
      #            img.draw_cross(cx,cy,color= (255,255,255))
      #            return cx,cy
      #-----------------------------通过面积进行识别最大的矩形
      def find_max_rect():
          max_rect = None #初始化返回的最大矩形
          rect_max_w = 0  #通过比较矩形的面积来判断矩形大小
          rect_max_h = 0
          for black_rect in img.find_rects(threshold = 25000):
              if (black_rect.w()*black_rect.h()) > (rect_max_w*rect_max_h):
                  rect_max_w = black_rect.w()
                  rect_max_h = black_rect.h()
                  max_rect = black_rect
      #            print(max_rect)
                  return max_rect
      #------------------------------------画矩形---------------------------------#
      def four_corners_draw(a):
          img.draw_line(a[0][0], a[0][1], a[1][0], a[1][1], (255, 0, 0), 1)
          img.draw_line(a[1][0], a[1][1], a[2][0], a[2][1], (255, 0, 0), 1)
          img.draw_line(a[2][0], a[2][1], a[3][0], a[3][1], (255, 0, 0), 1)
          img.draw_line(a[3][0], a[3][1], a[0][0], a[0][1], (255, 0, 0), 1)
      #    print(a)
          max1_rect = find_max_rect()
          if max1_rect:
              mode = 1
              img.draw_rectangle(max1_rect.rect(), color=(255, 0, 0))
              a = max1_rect.corners()
              four_corners_draw(a)                                        #画矩形
      #        print(a)
              new_xy, cx, cy =  shrink_rect(max1_rect.corners(), 10)     #计算等比例矩形
              new0_xy =new_xy           #打印四角点7 9 3 1
      #        print(new0_xy)
              newmid = Make_dian(new_xy)
      #        print(newmid)                       #打印2,4,6,8 点
      #        for w in range(0,7,2):
      #            img.draw_cross(newmid[w],newmid[w+1],5,color=(255,0,0))
      #        img.draw_cross(cx, cy, 5, color=(255, 0, 0))               #画出中心点
      #        for new1 in new_xy:
      #            img.draw_cross(new1[0], new1[1], 5, color=(255, 0, 0)) #画出缩小后矩形的点(十字)
      #            print(new1)
      #------------------------棋盘坐标9点
          if mode == 1:
              #------棋盘1---------------------------棋盘2------------------棋盘3--------------------------棋盘4
              data = [new0_xy[3][0], new0_xy[3][1], newmid[0], newmid[1], new0_xy[2][0], new0_xy[2][1], newmid[2], newmid[3],
             #棋盘5---棋盘6------------------棋盘7--------------------------棋盘8-----------------棋盘9
              cx, cy, newmid[4], newmid[5], new0_xy[0][0], new0_xy[0][1], newmid[6], newmid[7], new0_xy[1][0], new0_xy[1][1]]
              print(data)
              rois = [(data[0]-2,data[1]-2,5,5),
                      (data[2]-2,data[3]-2,5,5),
                      (data[4]-2,data[5]-2,5,5),
                      (data[6]-2,data[7]-2,5,5),
                      (data[8]-2,data[9]-2,5,5),
                      (data[10]-2,data[11]-2,5,5),
                      (data[12]-2,data[13]-2,5,5),
                      (data[14]-2,data[15]-2,5,5),
                      (data[16]-2,data[17]-2,5,5),]
              for r in rois :
                  img.draw_rectangle(r,color = (255,255,255))
                  for blobs in img.find_blobs([(10, 0, -76, 114, -118, 99)],roi = r):
                      img.draw_cross(blobs.cx(),blobs.cy())
              mode = 2
      ##-----------------------更新棋盘上的落子---------------
      #            for t in range(0,8):
      #                for blobs in img.find_blobs([(10, 0, -76, 114, -118, 99)], roi=rois[t]):
      #                    img.draw_cross(blobs.cx(), blobs.cy(),color = (0,255,0))
      #                    print(blobs.cx(), blobs.cy())
      #    if mode == 2:
    • 你把r打印出来,就能看到r的值不对。超出了图片的范围。
    • 没有,roi能打印在图现上,我怀疑roi的11值11不稳定,导致报错,如果是超出,是不是因为我设置了窗口的大小sensor.set_windowing((160, 120))
