  • Openmv使用星瞳AI训练出识别水果的模型后,运行时检测到水果后,卡住了,然后断开连接,该如何解决?
    • # This code run in OpenMV4 H7 Plus
      labels = [line.rstrip() for line in open("labels.txt")]
      class_num = len(labels)
          for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
              output = obj.output()
              for i in range(class_num):
                  print("%s = %f" % (labels[i], output[i]))
          print(clock.fps(), "fps")
    • https://ai.singtown.com/zh-hans/
      你加微信群,然后联系管理员帮你测试一下。
