为什么这段代码脱机运行后补光灯不亮,去掉除了补光灯外的代码后又能亮
请在这里粘贴代码import sensor import time import display from pyb import UART, LED from pyb import Pin, Timer sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.LCD) #128x160 sensor.skip_frames(time=2000) clock = time.clock() lcd = display.SPIDisplay() black = (32, 100, -128, 127, -128, 127) uart = UART(3, 9600) # 初始化定时器 timer = Timer(2, freq=50000) light = timer.channel(1, Timer.PWM, pin=Pin("P6")) light.pulse_width_percent(100) # 初始设置为100%占空比 # led_blue = LED(3) # led_blue.on() # 50kHz pin6 timer2 channel1 while True: time.sleep(1000) img = sensor.snapshot() blobs = img.find_blobs([black], invert=True, roi=[0, 60, 128, 30]) if len(blobs) == 1: # led_blue.on() img.draw_rectangle([0, 60, 128, 30]) img.draw_rectangle(blobs[0][0:4], color=(255,0, 0)) lcd.write(img) uart.write('#' + str(blobs[0].cx()) + '$') print('#' + str(blobs[0].cx()) + '$') elif len(blobs) == 0: uart.write('S') print('S')
LCD扩展板和光源扩展板引脚冲突了。
