  • 用阈值编辑器得出的蓝色阈值范围,用的也是IDE自带的示例,但是始终识别不出蓝色,这该怎么解决
    • # This work is licensed under the MIT license.
      # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      import sensor
      import math
      threshold_index = 0  # 0 for red, 1 for green, 2 for blue
      thresholds = [
          (30, 100, 15, 127, 15, 127),  # generic_red_thresholds
          (30, 100, -64, -8, -32, 32),  # generic_green_thresholds
          (16, 40, -71, 29, -98, -22),
      ]  # generic_blue_thresholds
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)  # must be turned off for color tracking
      sensor.set_auto_whitebal(False)  # must be turned off for color tracking
          for blob in img.find_blobs(
              [thresholds[threshold_index]],
              pixels_threshold=200,
              area_threshold=200,
              merge=True,
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255, 0, 0))
                  img.draw_line(blob.major_axis_line(), color=(0, 255, 0))
                  img.draw_line(blob.minor_axis_line(), color=(0, 0, 255))
              img.draw_keypoints(
                  [(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20
    • 你代码里的阈值和阈值编辑器的不一致。
    • 我改过,还是不行,试过提取好几个不同的蓝色物品的阈值来试验也不行
    • 你的代码有问题,threshold_index是0,用的是 (30, 100, 15, 127, 15, 127)这个阈值。如果你想用 (16, 40, -71, 29, -98, -22)这个阈值,threshold_index需要改为2。
