  • 出现“module object has no attribute "load"是啥原因,按照视频教程弄得
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 运行这个代码:
      import sensor
      import ml
      from ml.utils import NMS
      import math
      import image
      sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
      sensor.set_windowing((240, 240))  # Set 240x240 window.
      sensor.skip_frames(time=2000)  # Let the camera adjust.
      min_confidence = 0.4
      print(model)
      model = ml.Model("trained.tflite", load_to_fb=True)
          (255, 0, 0),
          (0, 255, 0),
          (255, 255, 0),
          (0, 0, 255),
          (255, 0, 255),
          (0, 255, 255),
          (255, 255, 255),
      # FOMO outputs an image per class where each pixel in the image is the centroid of the trained
      # object. So, we will get those output images and then run find_blobs() on them to extract the
      # centroids. We will also run get_stats() on the detected blobs to determine their score.
      # The Non-Max-Supression (NMS) object then filters out overlapping detections and maps their
      # position in the output image back to the original input image. The function then returns a
      # list per class which each contain a list of (rect, score) tuples representing the detected
      # objects.
          n, oh, ow, oc = model.output_shape[0]
          nms = NMS(ow, oh, inputs[0].roi)
          for i in range(oc):
              blobs = img.find_blobs(
                  threshold_list, x_stride=1, area_threshold=1, pixels_threshold=1
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = (
                  nms.add_bounding_box(x, y, x + w, y + h, score, i)
          return nms.get_bounding_boxes()
          for i, detection_list in enumerate(model.predict([img], callback=fomo_post_process)):
              if i == 0:
              if len(detection_list) == 0:
              for (x, y, w, h), score in detection_list:
                  print(f"x {center_x}\ty {center_y}\tscore {score}")
          print(clock.fps(), "fps", end="\n")
