  • 已经将代码和训练好的模型和txt文件烧进openmv根目录里,但依旧无法调用模型。设备是H7plus。
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 具体的报错是什么?
