  • 求助: 'module' object has no attribute 'classify'
      大神帮忙看看,我这个是训练过程出错了吗?
      AttributeError: 'module' object has no attribute 'classify'
      看着似乎是tf模块没加载上,没搞明白为啥,是训练包生成的py文件
    • 4.5.6之后把tf删除了,替换成了ml库。
      # This code run in OpenMV4 H7 Plus
      import sensor, image, time, os, ml
      model = ml.Model("trained.tflite", load_to_fb=True)
      labels = [line.rstrip() for line in open("labels.txt")]
      class_num = len(labels)
          scores = model.predict([img])[0].flatten().tolist()
          for i in range(class_num):
              print("%s = %f" % (labels[i], scores[i]))
          print(clock.fps(), "fps")
    • 嗯,版本问题,固件不兼容了,需要回退版本4.5.4
