  • 使用h7plus执行扫码、识别圆形两个任务,运行时帧率降低怎么解决?
      from machine import UART
      from pyb import Pin, Timer
      def find_max_circle(circles):
          max_size = 0
          for circle in circles:
              if circle.r()>max_size:
                  max_circle = circle
                  max_size = circle.r()
                  return max_circle
      sensor.skip_frames(time = 500)
      sensor.set_auto_gain(False)
      sensor.set_hmirror(True)    #水平方向翻转
      sensor.set_vflip(True)  #垂直方向翻转
      # 50kHz pin6 timer2 channel1
      light = Timer(2, freq=50000).channel(1, Timer.PWM, pin=Pin("P6"))
      light.pulse_width_percent(100) # 控制亮度 0~100
      uart = UART(3, 115200)#P4-TX P5-RX
      rw=0
      x=0
      y=0
      data=([0xFE,0xE0F,x,y,rw])
          img.lens_corr(1.6)
              rw=int(code.payload())
              data=bytearray([0xFE,0xE0,x,y,rw])
              uart.write(data)
              print(rw,data)
          circles = img.find_circles(x_stride=5, y_stride=1, threshold = 4000, x_margin = 20, y_margin = 20, r_margin =20,
                      r_min =6, r_max = 100, r_step = 2)
          if circles:
              max_circle = find_max_circle(circles)   #找到最大的圆
              area = (max_circle.x()-max_circle.r(), max_circle.y()-max_circle.r(), 2*max_circle.r(), 2*max_circle.r())
              img.draw_rectangle(area, color = (250, 0, 0))
              x=int(max_circle.x())
              y=int(max_circle.y())
              uart.write(data)
              print(x,y,data)
    • 解决不了,这两个算法都很耗时。
